Headliner...
Car: 1986 Camaro z28
Engine: 350 v8
Re: Headliner...
teke out the middle light first.. pop the cover and use need nose and turn the metal clips out.. then pull off the rear seat belt covers. next take out the front too fold down mirrors/ sunvisors.. unscrew the 3 screws on both sides... there are 2 plastic clips the will hold the front up still.. just pull then straight down towards you and it will fall..... warning... these stock headliners are extremely weak... the brake apart really easy.. so be careful
GL
Douglas
GL
Douglas
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Headliner...
The short answer:
Remove the stuff holding it into place (yes, it's really that easy).
Long answer:
http://www.iroczone.com/technical/headliner
Long answer:
