my $20 dollar carpet fix
Old Aug 22, 2009 | 11:05 AM
vulcanravenxvg's Avatar
Car: 89 RS Camaro
Engine: fuel injected 2.8 6 cyl
Transmission: Automatic
Axle/Gears: Stock crap
can you really fix your old carpet with a bit of ingenuity and 20 bucks??!! yes yes you can. and heres how I did it. now alot of people have doubted that you can fix a headliner for 20 bucks but i wanted to prove that if you can do the headliner you can also do your carpet... on a budget. heres how lets walk through the carpet first.
1. go to walmart and get yourself and purcahse 2 rolls of ozite brand carpeting... the come in rolls of 36" by 72" and they are perfecct for the entire driver or passenger side flooring.... but you need 2 rolls cause it wont cover both sides.
2. go to autozone napa or any other parts store and pick yourself up a can of heavy duty carpet and headliner adhesive... dont be cheap and get the 6.00 not so heavy duty crap... you will regret the results of your job.
3.remove your carpet.. GO CRAZY! you wont be needing any of itr so take it out by whatever means nessasary... dont forget tho that the console holds down the carpeting in the center so make sure you do a good job or just take the console out.
4. begin by making a rough positioning of the carpen on your floor.. begin to trim the excess and make cuts to allow for the seatbelt and the contour of the floor in the front by the pedals. this is the hardest step and you must be careful that your razor stays sharp as your making your cuts... replace your blade often. also make sure to make small cuts to allow for the seat bolts to pop through the carpet!
5 pick a corner and begin to spray the adhesion spray. make sure you smooth out any ripples with your hand as you move along. make sure you spray the adhesion spray on both the carpet and the metal! that way you have a bond that wont release as your move your feet on the carpet when driving.
6. enjoy the new lightweight (by far) carpet in your ride! you may want to consider adding bottom padding underneath your carpet but i diddnt... as your driving its not very noisy tho... even on dirt roads... the padding does very little to deaden the noise... and it weighs more so i wouldnt put it in... but thats up to you! maybe tomorrow i will document how to do the headliner... until then enjoy and let me know if you would like help on either project!
Attached Thumbnails my  dollar carpet fix-bare.jpg   my  dollar carpet fix-jacket.jpg   my  dollar carpet fix-finished-close.jpg
Old Aug 22, 2009 | 11:11 AM
Car: 89 RS Camaro
Re: my $20 dollar carpet fix
heres the materials the carpet instalation requires... all for around 20 bucks plus heres another pic of the carpet completed and installed on the driver side. passenger side pics coming soon!
Attached Thumbnails my  dollar carpet fix-mat.jpg   my  dollar carpet fix-finised.jpg
Old Aug 22, 2009 | 01:21 PM
Car: 89 RS Camaro
heres the passenger side completed... I would like to get some opinions. anybody? is this something you would do to your car? keep in mind im attending college and dont have the cash to throwdown on a carpet kit that costs 150 bucks. and this car is just my daily driver that my girlfriend liked to whine about the lack of carpeting in. hahah i think its a cheap reasonable fix allowing me to put my money where it really belongs... in the motor and making it run reliably. I thought it would be a nice guide to anyone looking to replace their carpet but finds themselves short on dough.
Attached Thumbnails my  dollar carpet fix-pside.jpg   my  dollar carpet fix-pside2.jpg
Old Aug 22, 2009 | 03:30 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Looks good, report back in a few weeks/months and let us know how its holding up.
Old Aug 22, 2009 | 04:07 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
Throw down some floor mats and your right to go.
Old Aug 22, 2009 | 05:11 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
nice! i might have to try that! its cheap enough and looks great....good alternative to buying the expensive molded carpet. idk about using the spray adhesive all over...i have sub and stereo wiring running under the current carpet. i'd prob just spray it in the foot wells and hatch. good job!!!
Old Aug 22, 2009 | 05:17 PM
picasso_88's Avatar
Car: 1986 Firebird
Engine: Chevy V8
Looks very nice! Especially for the minimal investment. I actually used that same exact carpet from walmart In my Fiero that I had last year and it held up real well even through the winter.
Old Aug 22, 2009 | 06:01 PM
Car: 89 RS Camaro
the spray adhesive held together pretty well. i did a test spot with this carpet on the metal and it was a sucker to pull up.. it even left the fibers behind on the metal so it had a really good bond. its kinda like the same material that they use on the sides of subwoofer boxes if anyone wants to know the quality of the walmart carpet.. just a tad thicker though.. I diddnt want ppl to think that this is a substitute to molded carpeting (which is by far supreior) but this stuff is close... very close. if done correctly.. next project im posting pics of is how i did the headliner for about the smae price... i have to find my old memory card with the pics tho.. stay tuned!
Old Aug 22, 2009 | 06:03 PM
Car: 89 RS Camaro
i also have the sub wires.. but carpeted right over em!
Old Aug 23, 2009 | 03:01 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Huh, looks much nicer than i would have expected. Good job
Old Aug 24, 2009 | 09:23 PM
Car: 89 RS Camaro
headliner next? i lost those pics on how I did it... so maybe ima take my headliner down and do it again... I was thinking about switching the color to red anyhow... pm me or something if you wanna see how I did it... if i get enough messages I guess I will go and redo it and do a write up with pics again but only if ppl want to c how I did it... again for about 20 bucks in material.
Old Aug 25, 2009 | 01:38 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
...........Good job.
Old Aug 25, 2009 | 02:31 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
not bad. I remember doing this over my tan carpet (to black) which held up nice, but eventually my corners started creeping in so I went to the junkyard and got a black carpet from a black interior fbody. It looks good. I'm sure the Halo3 helped!
Old Aug 25, 2009 | 07:06 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
im going to keep this in mind...
i hate my pink interior!
Old Aug 25, 2009 | 07:17 AM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
i just dont like the idea of gluing it to my floor. now if i added some back padding i think i would glue it to that instead of the floor.
Old Aug 25, 2009 | 10:26 PM
Car: 89 RS Camaro
You bet halo 3 helped! but cod4 helped even more... lol
Old Aug 26, 2009 | 07:59 AM
Dink2142's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0L V8
nice lol i would like to see the headliner if it wouldn't be too much trouble.
Old Aug 26, 2009 | 10:45 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
thats what im talking about. good job!
Old Aug 26, 2009 | 12:53 PM
Car: 89 RS Camaro
Hmm. give me lest say... a week or so? I have alot to accomplish so i will revive the thread when i put pics of the headliner up.
Old Aug 26, 2009 | 01:20 PM
Dink2142's Avatar
Engine: 5.0L V8
okay thanks
Old Aug 26, 2009 | 02:00 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Is gluing it down really the best way to do it? I mean what if you need to chagne the carpet again in another 20 years?
Old Aug 26, 2009 | 02:04 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Omfg That is exactly what i said.. I'm addicted to both those games on XBL.
Old Aug 26, 2009 | 02:23 PM
Stephen's Avatar
Car: 87 GTA
How well did you get it to contour to the passenger side front foot well, in front of the front seat? That seems to be the biggest problem in our cars.
Old Aug 26, 2009 | 02:59 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
I think when i replace my carpet, I will fasten down a plate or something to make the floor flat..
Old Aug 26, 2009 | 04:27 PM
Dink2142's Avatar
Engine: 5.0L V8
Yeah or reshape it with that piece of metal so it is easier to contour it. xP
Old Aug 26, 2009 | 08:22 PM
Car: 89 RS Camaro
the carpet is forgiving because its thin... and i made appropriate cuts with the razor to get it nice
Old Aug 26, 2009 | 08:27 PM
Car: 89 RS Camaro
Im counting on 2 things.. 1 the floor will rot out again or 2 the carpet is thin enough to carpet over again with the expensive molded stuff. let me get back to you in 20 years. hahahah ill let you know what i did.
Old Aug 28, 2009 | 07:58 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
when you decide to pull out that capet when it's worn out, use a heat gun to soften the glue to pull up the carpet. I'm switching my interior from red to grey... the headliner was only about 5 years old... heatgun and patiance got the headliner foam off of the backer board.
Old Aug 28, 2009 | 03:06 PM
Car: 89 RS Camaro
hey I wanna switch from grey to red! would you wanna get rid of the speaker covers and the armrests and door panels? and as far as the back plastics.. I can trade you.. my plastic is mint. interested?
Old Aug 30, 2009 | 10:31 AM
uemf's Avatar
Car: '86 Firebird
if yours are mint, I'd feel like i was stealing them. some of my back panels show a lot of sun fade/ sun damage. and where are you located ? as you can see. I'm in Corpus Christi Texas. shipping might be expensive. I'll try to get some pics of my pieces. we can go from there... might take a couple of days for me to do this.
92firebirdguy
Sep 1, 2016 07:53 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
F-body-fan
Sep 19, 2015 09:02 PM
Denricci22
Sep 18, 2015 09:02 AM
