Speedometer trouble
Old Aug 30, 2009 | 11:27 AM
91CAMARO GUY's Avatar
Car: 91 camaro rs
Speedometer trouble
Hey, I was driving to work when my speedometer needle dropped down to zero and a poof of smoke came from behind the dash but all the other gauges still worked. Wondering if anyone has had this happen or know what it could be and how hard it is to get behind the dash.
Old Aug 30, 2009 | 12:14 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Speedometer trouble
You probably smoked a section of the circuit board that manages all the guages in the cluster. Once you get to it, it should be pretty obvious if you saw smoke. I have a TA, not a Camaro but it is probably the same.
Accessing it isn't hard but you have to go from the front and remove the dash pieces first. Pull of the lower knee panel and the facia that surrounds the guages and AC outlets. Then remove the guage cluster and turn it over. The flexible circuit board is on the back side. Not complicated hardware anywhere in the process. Good luck.
Old Aug 30, 2009 | 12:50 PM
Car: 91 camaro rs
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
