Sandblasting my Rearend
Old Jul 31, 2007 | 02:39 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
I have a 9 bolt rear, complete with brakes and sway bar. I want to sandblast it to remove some rust and then give it a quick shot of paint.
I am having a guy install new gears. So...should I blast and paint the rear before he works on it or afterwards.
Also, when I blast it, do I need to remove the brakes and brakes lines? Or can I just wrap up the rotors and calipers in cardboard or plastic or something?
Old Jul 31, 2007 | 03:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Sandblasting my Rearend
If you're having gears put in, the entire thing's going to be apart with no brakes on it anyway, so clean it and paint it then.
Old Aug 2, 2007 | 08:58 PM
84bandit's Avatar
Yeah, we put a dana under our drag car and cleaned it, sandblasted it, cleaned the inside with a wax and grease remover. then put it together
btw use styrofoam cups in the axle tubes and frt of centersection to keep the sand out(these won't hold up to a lot of direct sand but they keep 99.9% out of the rear and),and put the cover over the back tokeep the sand out.
Old Aug 2, 2007 | 09:27 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
sounds painful
Old Aug 2, 2007 | 10:41 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
When I sandblasted my rear i left the pumpkin cover, rotors, and backing plates on it. The rear was already worked on before I got it, but I wanted to freshen it up before I put it on. I ended up going with a summit girdle and 4th gen brakes so everything worked out well, now getting the old third gen rotors off, that's a whole different story
Old Aug 4, 2007 | 01:01 AM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
b4 the gears are put in,since blasting is such a joy
UltRoadWarrior9
Apr 28, 2020 10:39 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
