quick paint question(s)
Old Aug 14, 2007 | 06:39 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i just picked up a 36/24 sway bar and wonder bar setup off ebay. it has light surface rust- its actually in pretty good shape from '86. i plan to take a wire brush to them to get off any loose paint/ rust.
here's my question(s): i'm using rustoleum stops rust gloss black spray paint. should i have to/ do i need to prime the pieces before i paint them? do i need to take off all the old paint before priming? is there some kind of pre-paint surface cleaner i can use to make sure its totally clean and ready for paint? i had just planned on using brake cleaner and was wondering if there's some sort of alternative.
i'm not looking for perfection i just want to to be decent.
suggestions?
Old Aug 14, 2007 | 07:16 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: quick paint question(s)
If you're not looking for perfection,you're method should work fine.Let us know how it turns out.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
