touch up paint tips?
Old Aug 24, 2007 | 09:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I got a little bottle of touch up paint with the brush in the bottle, to fix some paint chips on my car.
I'm doing what I would call a heinous job so far. Is there a good way to fill in the little dips left from paint missing? So far I scuffed it a bit with a tiny piece of sandpaper, then brushed over it.
Can I wet sand this later to smooth it all out? After using enough paint to get the surface level of course. What grit? Or maybe just use a polisher with some polishing liquid?
Any tips are appreciated.
Old Aug 27, 2007 | 10:34 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: touch up paint tips?
Ive had the same problem with small rock chips and one bigger scratch, when I went to the shop who painted my car for advice, They told me to fill it in a little at a time with the touch up, do a thin layer let it dry, the same process until its a little above level and then buff it until it is level and then polish it, for the polish I used scratch out and it did a really good job and unless you know its there and you are really eyeing it you cant see them. Hope this helps some
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
scotrans am
Sep 5, 2015 04:26 AM
L0tuS
Sep 4, 2015 11:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
