Evoluzione Build Pics...with vertical doors
Old Nov 13, 2007 | 11:36 AM
  #101
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Evoluzione Build Pics...with vertical doors
yes, because good is the rare 4.7L V8 and a 3.43 rearend. both of which i never heard of until today.
Old Nov 13, 2007 | 11:41 AM
  #102
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Huh?
I am assuming ur referring to my specs on the left... the 4.7L V8 is in my truck and the 3.43 rear end is from a fourth gen...
Old Nov 30, 2007 | 12:45 AM
  #103
evoluzione2's Avatar
wow...havent been on here in a while and i didnt even realize this thread had continued a bit...
answers:
acclr8n--no we arent driving the car. i actually took EVERY wire out of the car and I am replacing everthing with a ron francis wiring kit to clean the whole car up. therefore, it obviously doesnt run right now. plus the whole front end isnt mounted.
stephen--just info, the VD kit we used was from GT Factory...heavy duty kit with replcaement struts for more lifting power. a 250lb and a 150lb on each door i believe. kit runs about $999 from www.tunerracing.com
Toplezz--thanks for the enthusiasm, but i have two of my own that work just fine and I like our car
as for the twin turbo discussion...i dunno whats right. im not a make/model genius...i just typed in tinw turbo testarossa and came up with that picture on google. so it could be wrong, i dunno.
anywho...car update:
like i mentioned, its getting rewired right now. I also worked on the rear hatch (getting struts on and such) but I tightened the hinge bolts too much and shattered the entire glass (dumb mistake...shoulda known better) and replaced it with a new one wit ha third brake light that I plan on molding the rear hatch piece of the kit around. gonna replace the steering column with a 4th gen column to get a certain wiring plug...i'll post a question about that later in a different category cuz im kinda stumped on it. i got the entire interior gutted now. and i mean entire. mounted the fuse panel in the passenger area, above the kick panel, closer to the door rather than farther. battery is relocated to the t top storage area ( will be covered by custom audio install in the future)
Old Jul 19, 2008 | 07:03 PM
  #104
hmmm.....bump for kicks?
Old Jul 19, 2008 | 07:48 PM
  #105
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I wish you wouldn't. I can't take the emotional battery that ensues.
How's it coming?
Old Jul 20, 2008 | 11:09 AM
  #106
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
only if you've got some more pics
Old Apr 2, 2016 | 11:28 PM
  #107
nyckid's Avatar
updates?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
