Firewall rust.... low miles car
Old Sep 22, 2007 | 07:06 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Hello all, I have a 19898 T/A with 30k miles, but it sat parked in a salt air environment for 8 years. The result is a mint car with rust under the windshield drain. As you can see it is oozing through the seam in the fire wall. Any help would be great. I was planning to rip all the factory sealant off from inside the plenum there, and POR-15 the heck out of it. Again all help is welcome
T/Y SHAWN
Attached Thumbnails Firewall rust.... low miles car-firewall-1.jpg   Firewall rust.... low miles car-firewall-2.jpg
Old Sep 23, 2007 | 08:41 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: Firewall rust.... low miles car
Doesnt look bad, i'd say you have a decent enough plan in using POR15 on it.
Old Sep 24, 2007 | 11:50 PM
ludacris3463's Avatar
mine did the same thing, that is the best way to go
Old Sep 25, 2007 | 12:52 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
It looks like mostly surface rust, and should clean up. My uncle, now deceased, was a design enginner for Chevy for many years. He used to joke that GM believed that if you can't see it, it does not need paint on it. There are lots of places on these 80's F-bodies that either never were painted, or just had a faint dusting of paint. My 86 is a mountain car, never in salt air, never driven in the winter, or on road salt. It has 27K miles, and has been stored most of it's life in an air conditioned basement garage. It still developed a couple of surface rust spots. The worst was where the trunk well is spot welded to the rear of the car where the bumper is attached. I cleaned all of the rust off with a wire brush attachment for a grinder, then painted it with with a rust inhibiting primer, then three coats of black enamel. One of my 83's did the same thing where the rear bumper mounts to the back of the car, and where the crimped lip on the leading edge of the hood is. Cleaned the areas up in the same manner, and primered, then painted. That was in 1990. There was no evidence of rust returning when I sold the car in 2003. Most everyone says that you can't stop rust, but you can slow it down. Charles
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
kah992
Aug 19, 2015 02:55 PM
kyle5647
Aug 7, 2015 03:08 PM
