Bent Bumper Cover
Old Nov 5, 2007 | 03:04 PM
mr_han_solo's Avatar
Car: 1986 Camaro Coupe
Engine: 2.8L V6
Bent Bumper Cover
Hello,
Unfortunately when I got lazy and quit working on my car for awhile, I propped stuff against my rear bumper, now it seems that the cover is bent where I had something leaning against it. Is their any to straighten it back out?
Old Nov 5, 2007 | 03:49 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Bent Bumper Cover
i have never done this but i want to say use a heat gun and some lite pressure with a flat object
Old Nov 5, 2007 | 04:02 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
A heat gun may work, but urethane is so flexible it is really going to want to stay bent, since having weight on it stretched the urethane. I have had some good luck w/ heating and bending urethane, but I have also had some really bad luck. It's worth a try, you aren't going to make it any worse.
Old Nov 5, 2007 | 06:12 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
we used to set bumpers out in the sun at the body shop (plastics have a memory, and want to go back to their original shape) if you use a heat gun be very careful not to overheat it, if you can get behind and push it do that while it's still cold (if you start when hot it may over do it) if it doesn't want to move then heat it a little and lightly push out (you may find just the heat brings it back though)
Old Nov 5, 2007 | 06:48 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
exactly what I was going to say.
Old Nov 6, 2007 | 01:18 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
heat it with a heat gun and push it out with a blunt/flat object then when its close to shape remove the heat gun and pour cold water on it. like others have said be carefull not to melt it.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
dbrochard
Oct 3, 2015 12:43 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
