need advice on body work..filler application....
Old Nov 10, 2007 | 10:06 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
i bought a project 85 irocz for 500 bucks and down the passenger side there is a line like a a scrape it is less then a 1/2 inch deep but besides from painting ive never done filler or bondo work help me guys i got another camaro but my mustang is my dd cant wait to get his beast on the street
Old Nov 10, 2007 | 05:46 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
Re: need advice on body work..filler application....
try and push as much as you can out.. 1/2 inch of bondo would be a little much.. you want to put as little as possible and in thin layers not all at once...
Old Nov 10, 2007 | 06:56 PM
EvilCartman's Avatar
Car: '82 Z28
If you can't push it out, rent or buy a stud gun. It spotwelds pins onto the bare metal so you can slip over the slide hammer to take out the dents. Just slowly work the area and don't try and pull everything out all at once.
Old Nov 10, 2007 | 07:33 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
stud gun is the way to go, they're not ridiculously (sp?) expensive at eastwood either.
Old Nov 10, 2007 | 07:51 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I don't know the exact name of it, but I recommend something even better than that if you rent. Use a self-welding dent puller, no need to mess with studs and makes it easier to feel the metal as you go. After grinding all paint/primer from the damaged area, simply place the slide-hammer where you want, hit the switch (it welds itself to the metal), slide-hammer as needed, give it a light twist to break the weld and move on. When you're done with that, make a few passes with the grinder to smooth everything out and feather the paint back with a D/A, then apply filler.
Old Nov 10, 2007 | 08:23 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I've never seen one of those,you got a link to one?
Old Nov 10, 2007 | 10:48 PM
Car: '82 Z28
Forgot about that option since I've only heard about it once. Friend works at a body shop and he told me about that a couple months ago.
Old Nov 10, 2007 | 10:49 PM
Engine: that I like
No, I don't even remember what brand it is It's at work so I won't see it till monday, it's around 15 years old though, so they've been around for a while.
Here we go, I found it
https://weldingsupply.securesites.co.../lencopull.gif
Old Nov 10, 2007 | 11:42 PM
jay92,85,79's Avatar
Car: 85z28,
Them are great. But the down side the end has to stay clean. And they are not cheap.. but they are nice to use. the stud weld is cool cuz he can weld a bunch in a row and pull all at once(like 5 )
o could use the old school dent puller were u drill the hole. But if u do it this way u have to weld the holes up and paint the inside of the door. Not the best way but it works.
Old Nov 11, 2007 | 12:32 AM
Engine: that I like
If the metal is free of dust and whatnot, the tip stays cleaner much easier. But yeah, burn some debris and hear/see it "POP" and it won't work until you hit the tip with some 80grit.
Old Nov 13, 2007 | 09:39 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
pop it out to where the hole is 1/8 inch or less....thats what oem repairs on most vehicles call for
jhawkeye
May 25, 2022 06:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
