Trans Am hood louvers
Old Nov 21, 2007 | 12:53 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
how do you remove the ones near the back of the hood? the ones near the nose I know how to get off, except my socket doesn't fit into one of the holes, any ideas? I tried searching, but couldn't find anything.
Old Nov 21, 2007 | 01:04 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Trans Am hood louvers
i had to get a circular saw bit at the end of my drill. got one at home depot.
basically i cut to make the hole bigger to get a socket in there to remove the front grill inserts.
the ones on the sides near the fenders and windshield i used i think a flat head screw driver. there are inner tabs u get under and press in gently and there are 2 per insert facing the fender.
if i were you id becarful. i was re-painting my car so i didnt care if i was gonna scratch the paint trying to get a flat screwdriver in there.
also to get a better idea where these tabs r, go to ebay and search for them and see if there is or someone can send u pictures of the underside of them.
its really easy, goodluck
Old Nov 21, 2007 | 01:13 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
alright, thanks. I was afraid I'd have to make the holes bigger. but I'm repainting too, nows the time to spray primer, so they need to come off.
Old Dec 3, 2007 | 05:06 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
You can get the front ones out without cutting anything, I did a few years back when I painted mine. I think I used some really thin channel-lock type pliers I had. The rear ones just pop out with a screwdriver.
Old Dec 3, 2007 | 02:13 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
yeah, I tried that before I widened the hole, it was working but taking too long. so I widened the hole and now its very easy to fit a socket in there, well worth it.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 6, 2015 09:03 AM
