Lugnut lock
Old Nov 26, 2007 | 09:37 AM
Tampa Hurricane's Avatar
Lugnut lock
When I purchased my 1992 Trans Am vert. it had locking lugnuts, but even though the seller said he had the key, it was not there. I have been to seven different tire places trying to see if they could get the locking lugnuts removed, and non of them could. The lugnut is an inverted locking one, which according to the last tire place I was at is an uncommon version. Does anyone with locking lugnuts know if they came with the inverted lock, or if this is a set that a previous owner purchased and added on to the car?
Does anyone have any recommendations as to where to go to try to get these locking lugnuts removed?
Old Nov 26, 2007 | 10:02 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Lugnut lock
confused on "inverted" locking lug nut...can you take a pic by any chance...?
there is cutting a slit in there and jamming a wedge to split the lug, there is jamming a socket on there (my personal favorite) or finding a tool that has absolutely nothing to do with lug nuts that manages to work.
Have you checked with a pontiac/chevy dealer that they possibly have universal keys???
The ones that came with my car had a little sticker in the center console stateing the company and the ### information to get a copy made.
Old Nov 26, 2007 | 10:44 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Lugnut lock
Yea pount a 12point socket on there usually a 13/16 works on all of them, that will take them right off.
Old Nov 26, 2007 | 10:53 AM
Re: Lugnut lock
According to the supervisor at the tire place, an inverted locking lug nut has the smooth front and sides, then there is a lip that lowers to get to the part of the lugnut that needs "gripped" to be able to be removed. I can try to get a picture and post it, but the lugnuts are sunk into the wheels, so the picture might not be too detailed.
Old Nov 26, 2007 | 11:39 AM
MNformula350's Avatar
Re: Lugnut lock
If they are factory locking nuts, the dealership has a full set, I used to work for both Pontiac and Chevrolet and they had a set of factory lug nut keys (there was like 24 different ones if I remember right) and will be able to remove them, but they charge an hour labor to do so.
When I was a full time Mechanic for Penske Auto Centers and Pep Boys, we had (actually I still do have) A locking lug nut removal kit.
I guess I don't see why a tire shop of all places wouldn't have this tool?
Anyway also has been stated, you can pound a socket over them usually and get them off that way.
Old Nov 26, 2007 | 12:47 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Lugnut lock
VICEGRIPS and maybe some penetrating oil if its on real tight
Old Nov 26, 2007 | 01:49 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: Lugnut lock
I agree with Rayzor, I took mine off with vicegrips when I lost the key. Just get them on there wicked tight and it'll work fine.
Old Nov 26, 2007 | 01:56 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: Lugnut lock
pretty sure a 9/16 socket is what i used...hammer it on and crank that bad boy off
Old Nov 26, 2007 | 02:16 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Lugnut lock
Tack weld a bolt onto it
5 mins at any exhaust shop
Old Nov 26, 2007 | 03:32 PM
NobleHdwe's Avatar
Re: Lugnut lock
a mechanic friend of mine has a tool that kind of slides on the lug nut like a socket, but had teeth that gripped the nut when you turned it, and it came right off. Don't remember the name of the mfg though.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
