Hatch wont stay open...
Old Nov 27, 2007 | 09:47 PM
vintageisbetter's Avatar
Car: 1992 Firebird, 1953 CJ3B
Engine: 3.1
Transmission: 5speed
lowering effects are coming off
i think i can fix it with glue. would super glue work the best for the time being.. tell i can take it off and replace it.
Old Nov 27, 2007 | 10:03 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: lowering effects are coming off
If you put glue on it, you run the risk of ruining the paint on your car or on the ground effect piece itself. If it is the front piece of the rocker panels that is coming off, you can get to the screws by simply taking off the kick panels and checking on the nuts to be sure they are tight.
The right quarter panel one is also easy to get to, just take out your spare tire. The left one is a bit more hassle because you have to take the entire interior plastic piece out.
If the one you are having an issue with (assuming its not all of them) is an easy one to get to, I recommend checking on the mounts before gluing them.
Hope this helps
Old Nov 27, 2007 | 10:08 PM
Engine: 3.1
the mounts are completey ripped. its the left front behind the bumper.
ya makes sense
Old Nov 27, 2007 | 10:17 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Hatch wont stay open...
ya makes sense
Is it the edge of the chin spoiler where it hooks into the fender? If so, the only thing I can thing to do is drill new holes near where the old ones were to remount it. Maybe someone else knows something better since I am not the most experienced person with ground effects
sheachopper
Jul 31, 2019 11:27 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
lewandom
Oct 1, 2015 08:15 AM
formula00ra
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
