Doors
Old Dec 3, 2007 | 12:11 AM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Doors
Thinking of going to manuel windows and locks. Do I need different doors or can I just swap the internal parts? And is there any way to make the hatch manuel close instead of it being pulled shut electricaly? Thanks
Old Dec 3, 2007 | 04:39 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Doors
The doors are the same you'll just need to swap over all of the necessary hardware. I know this from experience, as the replacement doors for my car were manual and I just swapped in all of my power stuff. There is even a rubber plug for the wire harness cutout in the front of the door. As far as the hatch goes, I think the manual latch has a different bracket welded to the body, but I am not 100% sure about that. If your doing this all for weight issues, you'll only be saving about 5-10 pounds, as the manual regulator weighs alsmost as much as power unit. Hope this helps!
Old Dec 4, 2007 | 12:37 AM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Re: Doors
Well, I already deleted the a/c, heater, radio, wipers, power steering, rear seats. The car is apart and ready for the rotisserie now. I just figured less wiring when I put it back together.
Old Dec 4, 2007 | 08:30 AM
Axle/Gears: 3.27 BW
Re: Doors
Yeah, I guess it wouldn't make much sense to have power windows and locks and nothing else!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
