Hood - missing weld-in nut
Old Dec 4, 2007 | 02:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have a hood I wanted to put on my car before paint. Where the hood attaches, there are 4 bolts through the hinges into the hood, there are nuts in the hood welded inside that these bolts attach to - 1 is missing - looks like the weld broke and the nut is lost.
Is there a way to get this hood to work? Can my body/paint guy fix it in anyway? Or should I not waste time with it and just get another hood before I paint.
Old Dec 4, 2007 | 02:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Hood - missing weld-in nut
without seeing a picture its kinda hard to say but it should be possible to tack another nut in place if you can get it back there..
Old Dec 4, 2007 | 03:12 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Just a thought. However, my thought may be way off base without seeing a picture of your situation. My thought is figure out what kind/type of nut you'll be needing. Run a bolt through said nut, (sketchy part without picture) fit nut with bolt into the mount point then weld nut into place. Remove bolt. From what my minds eye is seeing, you should be good to go.
Best of luck.
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
FormulasOnly
Sep 6, 2015 10:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
