Door plugs
Old Jan 3, 2008 | 03:23 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Door plugs
What is the point of the door plugs? Are they just there to drain water out? If so why leave them in at all? If not how often should they be pulled?
Old Jan 3, 2008 | 04:03 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Door plugs
do you mean those rubber gromet things on the bottom of the door? I pulled them out, they just restrain water and get clogged causing rust to form.
Old Jan 3, 2008 | 06:01 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Door plugs
The design was supposed to allow water to drain out and to not allow water in, obviously they don't work for some people but mine are still intact and do their job. I guess it depends on what part of the country you live in.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
Out-Cast
Aug 23, 2015 06:33 AM
g.l.mos
Aug 22, 2015 12:02 AM
BlackTopKing
Aug 19, 2015 12:13 PM
