OUTER WINDOW SWEEP REMOVAL/INSTALLATION
I am replacing the outer window sweeps on my '84 Camaro. I removed the panel, handle, window ****, window tracks and I am able to remove all but one screw that holds the window sweep on. The last screw is located closest to the door hinge, it's hidden under this little courner molding. I can't figure out how to get this screw out without practically taking the whole door apart. Can anyone help me out with this?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: OUTER WINDOW SWEEP REMOVAL/INSTALLATION
Take the window filler out to gain access to the last window sweep screw. It takes about 2 minutes to remove the filler and another 2 minutes to re-install it. It's better to simply work thru it rather than trying to find a way around it !
Car: rs convertible,06 dmax,07 tahoeltz
Engine: l03
Axle/Gears: 3:42 auburn posi unit
That is correct take the top two 10mm bolts out and loosen the bottom one you can then move the trim far enough to get to the last screw
