metal prep
Old Jan 24, 2008 | 10:27 AM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
metal prep
What's the best way to prep bare metal for paint? Got my 83' Camaro down to bare metal and have smoothed out very small dings with bondo. I guess wash it real good and then what to prep with before filler primer? Remember a product called prep-sol.
Old Jan 24, 2008 | 10:34 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: metal prep
i've been informed to use etching or self-etching primer on any bare metal applications. Otherwise i can't remember the name of the other primer to use. Epoxy maybe??? Can't remember. I've just used self-etching primer with success.
Old Jan 24, 2008 | 10:44 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: metal prep
Prep-Sol would be perfect right before laying primer/paint. But any good grease and wax remover is going to work. I would also the day before you paint wipe all the bare metal with Ospho or some sort of rust-inhibitor and let it sit overnight. Wipe it off the next day with the Prep-Sol and then paint. That way any little bit of rust that may have been starting gets nipped in the bud also.
Old Jan 24, 2008 | 10:52 AM
84redta's Avatar
Re: metal prep
oooh...that kinda prep, i thought he meant prep for paint...not prep for primer, i misunderstood. Yea any basic greese and wax remover. I've also heard of using paint thinner as it does the same thing and evaporates as it should.
Old Jan 24, 2008 | 10:55 AM
Car: '87 Trans-Am
Re: metal prep
You just want to be careful with thinners as if they do not fully evaporate or leave any residue, they are in fact a thinner and we all know what that does to paint. Wouldn't want any variables in the process that aren't necessary.
Old Jan 24, 2008 | 10:58 AM
84redta's Avatar
Re: metal prep
yea, i only did it once and with a forth coming paint job in the plans in spring, i'm not going to use thinner, lol.
Old Jan 24, 2008 | 08:26 PM
Engine: 383
Transmission: th350
Re: metal prep
Thanks. I'll wash it, degrease it, look for this ospho stuff, and use Prep-Sol right before the primer. Will shop for etching primer also. Just primed the 12-bolt with Eastwood primer. I used to use their Corroless Primer before and it worked great on the underside of the car. Now when I order it they send Rust Encapsulator.
Old Jan 25, 2008 | 06:37 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: metal prep
no need to wash it water and bare metal do not mix (rust).
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
