Driver Door Wobbles Up & Down
Old Jan 30, 2008 | 10:31 PM
xGR1Mx's Avatar
Hey guys,
Since I got my car the drivers side door has "wobbled" up and down a little bit. When i open it fully, you hear a *clunk!* and the door would drop an inch or two. Half the time I try to close the door and it doesn't close fully. My dad had told me I need to replace the door pins? If anyone could touch this subject a bit more for me, and perhaps where I could get the parts for this.
Thanks guys
Old Jan 31, 2008 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Driver Door Wobbles Up & Down
Your father is correct. Try Lon at TDS, a board sponsor, or here:
http://www.andyz28.com/catalog.htm
JamesC
Old Jan 31, 2008 | 06:35 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
You and your father may be in for some sticker shock as the upper hinge is a stressed member of the unit body. I've used the Top Down Solutions kit myself and also highly recommend it.
If you take the door completely off as I did becareful where you set it down. I put big crease in the thin outer panel balancing it on a milk crate. Stupid.
Old Feb 1, 2008 | 10:49 PM
xGR1Mx's Avatar
Thank you guys, this is a big help. Knew I could always count on thirdgen! Thanks again!!
Old Feb 3, 2008 | 04:56 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
$450 seems a little steep for some hinge pins and bushings....guys, our cars are known for being cheap and easy to repair. The factory setup is fine as long as care is taken opening and closing the doors. Dorman makes the pins and bushings for our cars, and you can buy them at any Pep Boys in the HELP section. Whole set for both doors should be under $35. Here's the link with the part number.
https://www.dormanproducts.com/cgi-b...st=1388:1146:0
Old Feb 4, 2008 | 09:05 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The dorman kit is only for the lower hinge. If you want to repair the upper hinge you're stuck buying the TDS kits. The upper hinges are totally different then any other bushing kit out there.
Old Feb 5, 2008 | 11:44 AM
ACCLR8N's Avatar
I only paid around $80 to fix my driver's door from TDS. Non-greaseable.
86IROC112
Aug 31, 2015 07:00 AM
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
chevyguy1999
Aug 16, 2015 08:49 PM
