87 ground effects on 86 camaro
Old Jan 31, 2008 | 06:56 PM
Hartmann's Avatar
will that work if they are both iroc z28s?
Old Jan 31, 2008 | 07:19 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: 87 ground effects on 86 camaro
Yes, there are three body kit styles. I believe the first is 82-84, the second is 84-89, and the last is 90-92. The only difference in the styles are the looks. All the mounting is the same as far as I know. An 87 kit on a 86 will definitely work
Old Jan 31, 2008 | 09:57 PM
Hartmann's Avatar
thanks alot.
Old Feb 1, 2008 | 11:56 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Have a sports coupe. Bought a wrecked IROC and transferred everything over. Just had to drill holes for the ground effects.
Old Feb 2, 2008 | 08:58 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am in the same boat. I have all the pieces but am still a little worried about drilling the holes in the right spots. Did you find and helpful tricks?
Old Feb 2, 2008 | 10:44 AM
Axle/Gears: 373s
Just a good ol' fashioned tape measure. To drill the holes, use a unibit step bit. it will give you a precise hole to allow your bolt just to go through perfectly.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
