door compatibility questions
Old Feb 5, 2008 | 03:15 PM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
I have an 85 z28 with manual windows and recently bought a 91 RS Convertible parts car. I plan on taking the doors and putting it on mine since both cars are black and those doors have power windows. My question is will those doors from the vert bolt right up to my hard top Z28? Also how hard would it be to wire the power windows to work with my car? And will the seats on both cars be interchangeable since i plan on using the seats from the vert.
Old Feb 8, 2008 | 08:39 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: door compatibility questions
As far as I know the door should be able to bolt right on. I replaced my driver's door off my 86 Trans Am with a driver's door off of I believe a 91 Firebird and it fit, it took a lot of tweeking but eventually it lined up so I see no reason yours shouldn't. I couln't tell you how hard it would be to wire the power windows in as both cars I used had power windows. The seats should be interchangable too. I have seats out of an 87 Trans Am and out of I believe an 89 Firebird.
Hope that helps at all..
Old Feb 8, 2008 | 08:52 PM
z28gsxr's Avatar
Engine: 5.7/5.0
thanx for the help :thumbsup
Frozer!!!
Jan 19, 2024 04:55 PM
NiG
Sep 2, 2015 06:54 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
