Somethings wrong with my lights
Old Feb 9, 2008 | 08:39 PM
Jakout125's Avatar
Im going to try to explain this the best I can, I have an 85 firebird and the headlight switch in the car to turn the lights on or off, it has the headlight button, and the button just to turn on your parking lights and then the off button, well normally when you turn on the headlights everything turns on with it parking lights, headlights, tails etc. and when you turn it off everything goes off and the lights go down, well with mine I turn everything on headlights go up and everything works as normal, but when I go to turn them off the headlights stay on, but the parking lights, tails, go off, I then have to hit the parking light button again and then hit off, and then the lights go down and everything is off, my question is why do I have to do this extra step, I tried replacing the headlight switch, but i still have the same problem, I dont know if the other one I have is bad also, or something is wrong with the wiring, any help is appreciated.
Old Feb 9, 2008 | 09:23 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Somethings wrong with my lights
if the headlight buckets themselves are what is causing your problem I would say try checking the headlight module on the firewall thats located directly above and behind the brake booster.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
