ss hood guys
Old Jan 4, 2008 | 03:00 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
ss hood guys
Are the ss hoods functional? is there enough material around the openings that the opening can be cut out?
Old Jan 4, 2008 | 05:21 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: ss hood guys
nope, not functional...atleast for the TPI engines they aren't....
Old Jan 4, 2008 | 05:53 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Re: ss hood guys
For a Carbed or TBI engine, yes. Just dremel out the material that is in the hole and smooth it out. The whole is a little right of the air cleaner.
If you really wanted to get technical you could make some sort of tube that goes from the hole to the element. I was planning on this, coupled with the TPI ducting up front. When the hood is closed, the hood snorkel would create sort of a top to the air cleaner, and then you could make the TPI snorkel come up to the cleaner and it would form the bottom ring. You could also dremel out the back of the SS hood and leave the back of what I just explained open to get even more air.
Old Jan 4, 2008 | 06:30 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Re: ss hood guys
great that is exactly the info i was looking for. How many inches does it rise up?
Old Jan 14, 2008 | 11:47 AM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Re: ss hood guys
They are all right on. I think mine rises about 2 inches. Never measured it. I can fit the 5'' Accel air cleaner set up under there with no problems.
Old Jan 22, 2008 | 06:25 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Re: ss hood guys
ok thanks. Im looking at the one on hawks, anyone have any issues when they got theres?
Old Feb 9, 2008 | 10:07 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Re: ss hood guys
I'm in the process of trying to fit mine. Major fittment issues. It sits OK on one side but sits up above the fender on the driver's side a good 1/2 "!! When I put a straight edge on the hood the curvature is not equal on both sides. There is a 'hump' at the leading edge of the driver's side hinge. I'm waiting for Bruce to call me back with any further tips that he might have but I really don't see how this will ever line up without cutting into the hood.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
