GFX conversion problem
Old Feb 13, 2008 | 11:32 AM
mike89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 355 TPI
Hey guys, I did some searching already and didn't quite find the same problem as I am having. I recently converted my 89 IROC gfx to the 91-92 style aero package. Everything went rather well for matching up except the rear of the side rocker panels. They will not lay against the rear quarter and have about a 1/2" gap. I used all the normal brackets for this area and they will not pull it close enough to the quarter. Any suggestions for how I could pull in or fill in this gap would be greatly appreciated. Thanks, Mike
Old Feb 13, 2008 | 12:36 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: GFX conversion problem
i am doing the same conversion to my 86 z28 and i didn't have any issues with them but did you drill new holes for thr brackets? i had to drill new holes because the old ones didn't line up. thats all i know man -Matt
Old Feb 15, 2008 | 09:08 AM
Car: 1989 IROC-Z
Engine: 355 TPI
Yes, I did drill the new holes for the bracket. The problem came with the bracket not being able to pull the rocker piece in flush with the rear quarter.
Old Feb 15, 2008 | 04:11 PM
19CAMARO85's Avatar
i had one issue on another ground effect... the door... the bracket slipped out from its place under the fiberglass and it didn't suck it up to the car. Chack and make sure it is in place. If not try some washers behind the quater to give it some more pressure to see if it gets tight. hope i helped some. -Matt
Old Feb 15, 2008 | 06:22 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Usually the GFX get weak in the area where the bracket tucks into and it will start to bend outwards. I heated mine with a small propane torch to soften it, pushed it back inwards and the problem was solved.
Old Feb 16, 2008 | 10:55 AM
Car: 1989 IROC-Z
Engine: 355 TPI
I didn't even consider the heating option. I may have to try that when I can get near the car again. I moved not that long ago and it's being stored in a different location. Thanks for all the suggestions guys I do appreciate it.
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
greenyone
Sep 2, 2015 03:39 PM
J.C. Denton
Aug 31, 2015 03:11 AM
LittleFranks
Aug 20, 2015 03:55 PM
