Inner Fenderwall
Old Feb 13, 2008 | 01:48 PM
AcesHi's Avatar
Inner Fenderwall
Been lurking on the website for years, first post. I tried searching and couldn't find anything about inner fenderwalls, not the plastic liner but the actual metal piece behind the fender. Anyone know where to get a replacement?
Old Feb 13, 2008 | 01:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Inner Fenderwall
You'd probably have to cut one off a junkyard car.
Old Feb 13, 2008 | 01:53 PM
AcesHi's Avatar
That is what I was dreading - I have been able to find replacement parts for everything so far except this.
Thanks.
Old Feb 13, 2008 | 01:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not really a replaceable part, it's a welded-in structural member.
Old Feb 13, 2008 | 02:00 PM
AcesHi's Avatar
Yeah... This was my first car and I really have no other option because I can't get rid of it - no matter how much the wife threatens me.
Old Feb 14, 2008 | 09:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
whats wrong with yours?
take a pic and send it. we might just be able to give you a few suggestions
Old Feb 14, 2008 | 09:56 AM
AcesHi's Avatar
When I was in college I lost the fenderwall skirt and didn't have the money to replace it, and then I drove it in Ohio for the next few years without it. Well the salt they use in the winters caused it to rust out. It is structurally safe, I think, but now that I have the resources and am restoring the car I figured I should replace it.
I am at work now but will upload pictures when I get home.
Old Feb 14, 2008 | 10:05 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
are you talking about the front or rear? The front would be a serious problem to replace because that's the structural section that the strut mounts to. If it's the rear, it's less of an issue but still a major task to replace it. You're more than likely better off repairing/patching what you have than cutting out the entire section and replacing it. The pictures will definitely help out in understanding the situation.
Old Feb 14, 2008 | 10:20 AM
AcesHi's Avatar
The front drivers side. I have everything out, strut, mounts, brake booster, resovoir, etc. I guess that's good to know, and probably explains why i haven't been able to find anyone who has done it before.
Old Feb 14, 2008 | 03:48 PM
Pocket's Avatar
Car: 91 Trans Am
Cut one out of a junk car but cut it with extra material
You can drill out the spot welds on your rusted one but some cutting will still be necessary
Its time intensive but not THAT bad of a job
Old Feb 14, 2008 | 08:57 PM
AcesHi's Avatar
I have the pictures, they are kind of hard to make out but most of the rust is at the seams so it would be tough (for me) to patch.
Image 28 is standing at the front looking back towards the cabin.
Image 29 is looking straight up at the strut mount.
Image 30 is standing at the front looking forward to the nose.
I think I am going to try patching first and if that doesn't turn out, I am going to try cutting it out and just replacing it.
Attached Thumbnails Inner Fenderwall-img028.jpg   Inner Fenderwall-img029.jpg   Inner Fenderwall-img030.jpg
Old Feb 14, 2008 | 08:58 PM
AcesHi's Avatar
By the way - thanks for all the suggestions.
Old Feb 14, 2008 | 11:05 PM
Pocket's Avatar
Car: 91 Trans Am
Thats pretty mild
Grind out the remaining damage and weld in a few plates
Old Feb 15, 2008 | 09:54 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I'm with Pocket. remove all of the undercoating and remove any loose pieces to really see how much damage you're working with. From the surface, it doesn't look like replacing the entire inner fender is required at all... which is very good news for you!
hickersoncory
Aug 26, 2009 05:10 PM
f50nut
Jan 21, 2005 12:02 AM
Camar92
Jun 1, 2003 10:39 AM
Marin
May 7, 2002 07:38 AM
