flexing hood
Old Feb 14, 2008 | 05:42 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
flexing hood
i am running a harwood lift off hood that seems to lift in the middle in the front . when the car is parked the hood sits perfect on the car but at about 45 mgh you can see the hood start to lift and flex. any idea how i can stop this from happening. after the car is painted this is going to cause the paint to spider and flake i beleive.
Old Feb 14, 2008 | 05:51 PM
Stephen's Avatar
Car: 87 GTA
Re: flexing hood
Nothing you can do. That's the flexing of the 'glass, being pulled up by the low air pressure at speed.
Like the wings of a plane. The low pressure area on top, combined with high pressure from underneath, causes it to flex & lift.
You might be able to re-route some under car air around the car, reducing the higher air pressure under the hood, to reduce or eliminate the flex.
Old Feb 14, 2008 | 06:37 PM
deadman's Avatar
Car: 89 camaro
Re: flexing hood
on the bottom side of the hood is a brace that surronds the hood ,would it be possible to mount a bracket to it and secure it to the bottom of the car with a cable therefor eliminating flex and it would be harder to steal than just pulling 4 pins and walking away or would the brace break or compromise the hood.
Old Feb 14, 2008 | 06:49 PM
Stephen's Avatar
Car: 87 GTA
Re: flexing hood
Originally Posted by deadman
...brace that surronds the hood...
There should be more than just the surround piece. Post up a pic of the bottom of your hood. I THINK I already know what your hood problem is....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
