front bumper
Old Feb 26, 2008 | 10:30 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
front bumper
hey,
I can remove the front bumper cover without touching the headlight mounts right?
Just a dozen clips and bolts and it pops off?
Old Feb 26, 2008 | 10:34 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: front bumper
four or five bolts/nuts matching it to each fender, 5-6 push pins underneath attatching it to the bumper support, and depending on firebird or camaro...6-8 7 MM bolts holding the optional dual air cleaner in on camaros/filler panel on firebird, and like 3 bolts holding the radiator support bracket on and it should pop off. Then the headlight bar should come off with the bumper on a camaro and headlights should stay attatched to the frame of a firebird. Once you start taking it apart it will become clear what is needed to be done.
Old Feb 26, 2008 | 11:30 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: front bumper
It's a 92 Camaro RS BTW, I always forget that part!
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
