Removal of Power Antenna
Old Mar 15, 2008 | 06:20 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
My power antenna on my 88' Trans Am died and no longer works. Since its mounted inside the passenger side fender, whats the easiest and sipmlest way to get it out and replaced??
Old Mar 15, 2008 | 06:25 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Removal of Power Antenna
remove the retaining nut off the top (has 4 dimples). I used a screw driver and a little hammer to make the nut rotate counter clockwise. From there once you get that off, take the angled "boot" off (slides off), then go underneath inside the wheel well by removing the inner fender plastic, and you will see the big motor, and towards the door, you will see one bolt holding the bracket that holds the motor, take out the one bolt and the unit will slide down. I have to assume that there is a tool to get that top nut off the top of the fender, but i haven't found one yet. Thats the free way that i just did mine.
Old Mar 15, 2008 | 06:30 PM
Engine: Vortec 357
sounds easy enough. thanks and ill see how it goes and if i run into any probs. ill make shure to ask.
Old Mar 15, 2008 | 06:39 PM
84redta's Avatar
if needed i put my manual antenna up in the parts for sale section if interested. I don't know if you have the manual to replace it unless your shaving/getting rid of it all together. Don't be afraid to ask, it's pretty straight foward. To pull it out completely to replace your going to need to pull the entire antenna cable from the radio and 3 wire plug from your power antenna relay underneath the passenger side dash to succesfully pull it out completely.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
