Saging doors causing minor window leak?
Old Mar 21, 2008 | 06:24 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
When i wash the car, a lil bit of water will come in from the top rear corner of the glass. The door sags pretty and was wondering if it could just be the saging door? The t-tops dont leak at all. Im getting the doors fixed in a few weeks. The Gm garage said $80 for both doors plus the pins.
Old Mar 21, 2008 | 08:28 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
Re: Saging doors causing minor window leak?
yeah, if the doors are bad then you can get some leaking. Could need new seals around the door.
Old Mar 21, 2008 | 09:14 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If you are going to do it do it with good parts that you won't be in the same shape in a few months.http://www.top-downsolutions.com/pro...products_id=38 or you can do http://www.top-downsolutions.com/pro...products_id=37
Old Mar 21, 2008 | 10:09 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Thats what i was gonna get but im not sure which one is better greaseable or non greaseable?
Old Mar 22, 2008 | 08:06 AM
Car: 1992 camaro
Axle/Gears: 3:73
I am giong with greaseable.
Old Mar 22, 2008 | 09:47 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
My doors leak in the same spot but only sag very slightly. Do you guys think that this could be the problem? Let me know how things turn out.
Thanks,
Dennis
Old Mar 22, 2008 | 10:46 AM
rangerlaxdude's Avatar
Car: 85 berlinetta
Engine: 350 carb
Transmission: 4 speed auto
well if your door is sagging it is because of the hinge. our door are already very heavy and this puts alot of pressure on the hinges and whenever the door is open and you lean on it to get out it bends the hinges and over time this makes it sag so maybe if you just change the hinges you could fix that
Old Mar 22, 2008 | 11:02 AM
Car: 1992 camaro
Axle/Gears: 3:73
Open the door then go to the back of the door try and lift on the back of the door. If it moves a little it's a good chance that the pin or bushing is wore.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
