92 Camaro spoiler
Old Apr 1, 2008 | 01:24 PM
Chevy3Girl's Avatar
Car: 92 Camaro RS 25th Anniversary
Engine: Built 400
Axle/Gears: 3.73 gears
92 Camaro spoiler
I've recently put a new spoiler on my car and now the trunk won't stay up. The spoiler is too heavy for the stock lid lift shocks (or whatever they're called.) Are there stronger ones that I can put in? And where can I get them? Thank ya'll.
Katy
Old Apr 1, 2008 | 03:11 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: 92 Camaro spoiler
maybe your old ones are just worn out?
Old Apr 1, 2008 | 03:15 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Old Apr 1, 2008 | 03:17 PM
Chevy3Girl's Avatar
Engine: Built 400
No it's not that. This spoiler really is heavier. But nice try.
Katy
Old Apr 1, 2008 | 03:22 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Katy
it could be unless the ones u have on now r new cause with mine there worn out a bit to where they will hold it up if the cover thing for the trunk isnt on but if i put it on the little extra weight keeps the trunk from staying up
Old Apr 1, 2008 | 03:25 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
you have a 92 rs, it originally had the little fin spoiler, right? well IIRC these shocks all vary in strength by model, for example the shocks for my T/A with the ridiculously heavy spoiler would be much stronger than those on your RS. and I would think these would be interchangeable, just my thinkin
Old Apr 1, 2008 | 03:36 PM
my82roc's Avatar
Car: 89 Iroc Convertible
GM did make different strength hatch struts to accomodate the different hatch weights with or without rear spoilers and and also the different types of rear spoilers.When I bought my 86 iroc it had an aftermarket pedestal spoiler and the struts wouldnt hold it up.I find hatch struts on a regular basis at junkyards and tried many pairs but none worked until I got a set from a formula firebird with the wrap around spoiler.They held it up without a problem.About a year later I removed that spoiler and just had the stock camaro lip spoiler and then the struts were too strong as I really had to lean on the hatch to close it.So I went with a set of weaker struts and its much better now.If you look at the end of the struts towards the rear there is usually a colored ring that wraps around the strut.Ive seen blue ,green,yellow...etc.I believe this is to signify the different loads they can handle.
Old Apr 2, 2008 | 07:21 PM
Chevy3Girl's Avatar
Engine: Built 400
Thanks ya'll.
Katy
Old Apr 2, 2008 | 07:39 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Yeah, get new hatch arms, just about any parts store has them, I don't have the Z spoiler, but with the new hatch arms I hit the button and my hatch shoots up on its own.
Old Apr 4, 2008 | 12:29 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I bought some at O'reilly auto parts and them things are STRONG, I bet they would lift 20 extra pounds easy.
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
AkDrifted
Aug 17, 2015 07:45 PM
