91" head light gears work in 87" motor?
Old Apr 1, 2008 | 10:51 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
hey guys I have an 87' Firebird and I got the gears from a 91' from the junk yard I was just wondering if the gears were interchangable (they did look like different motors). Thanks for reading.
Old Apr 4, 2008 | 01:38 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 91" head light gears work in 87" motor?
Yes. However, I can tell you that 99.9% of the time the gear isn't bad. It is what is (or in your case WAS) inside the triangular-shaped cavity or the gear that is bad. There were 3 small cylindrical-shaped hard gel inserts or bushings in that cavity. If you find a spoonfull of off-white colored chunks, that is what remains of your bushings. I sell two kits TDS 207280 & TDS 209280 to repair these 1987-92 Firebird headlight actuators. Download my instructions for the 209280 kit and you'll understand what I'm referring to. The instructions are in the lower left-hand corner of my site.
Lon Salgren
Top-DownSolutions
Old Apr 4, 2008 | 10:29 AM
mxcrazed's Avatar
Engine: None
Transmission: none
Thanks for the Info I didn't think anyone would come through. I didn't see where i could download your instructions I googled your item number but couldn't find them on your page.
Old Apr 4, 2008 | 11:39 AM
lonsal's Avatar
The instructions for most items I sell are on the lower left corner at the bottom under "Documentation". Here's a link to it in case you're still having trouble finding it:
http://www.top-downsolutions.com/Doc...structions.pdf
The kit: http://www.top-downsolutions.com/pro...products_id=87
Lon Salgren
Top-Down Solutions
Old Apr 6, 2008 | 04:16 PM
mxcrazed's Avatar
Engine: None
Transmission: none
I got all that stuff from the other motor I guess that I'll be alright It looks like those bushings are designed to fail before the gears do. if all else fails I guess I'll be purchasing a kit thank you for your time and energy.
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
