rear wing removal
Old Apr 14, 2008 | 12:21 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
rear wing removal
i have to take the rear wing off cause i'm getting ready for paint. does it just pop right off cause i nly found two bolts for it and they were in the back. how hard is it to put back on?
Old Apr 14, 2008 | 02:48 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Re: rear wing removal
If it is the regular spoiler, and not the Aero, then it has 4 bolts, 2 on each side.
One on each side might be exposed but the other is under a little circular plastic cover.
Once the 4 bolts are out, it will come right out.
Assuming its not the style with the 3rd tail light built into it.
Old Apr 14, 2008 | 03:57 PM
JRods Firebird's Avatar
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
Does the wrap around one have 3 on each side or 4 and is that called the Aero wing. Or is it glue towards the tips. Reasoning being I saw one at the junkward and I have the reg wing and would love that wrap around 1. thanks
Old Apr 14, 2008 | 04:02 PM
Stephen's Avatar
Car: 87 GTA
Wrap around/Aero, is only 4 nuts too. The wing itself has studs. Unplug the 3rd brake first, as it comes up with the wing, then 2 more nuts to take it off the wing.
Old Apr 14, 2008 | 04:36 PM
So you have to remove the whole wing and glass in order to get it. I was hoping to just remove the wing itself and remove my reg and install it on mine. Are the studs welded on or rivet. thanks
Old Apr 14, 2008 | 05:16 PM
Stephen's Avatar
Car: 87 GTA
The wing is bolted to the deck of the hatch.
Here .
Just pull the interior panel....4 screws.
Unplug the 3rd brake light. You'll find 4 nuts. Remove, those & lift the Aero wing, with the 3rd brake light attached. 2 nuts (,aybe bolts, can't recall) and the 3rd brake light housing comes off the wing.
Old Apr 14, 2008 | 06:58 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
If you're planning on getting the wing from a junkyard car,I would ask them how much for the whole hatch assembly.
If you want to mount the aero spoiler on a standard firebird you'll have to remove both spoilers,and then fill the holes in your non-aero spoiler equipped birds decklid and then redrill holes for the aero spoiler.
Seems to me that it would just be easier to replace the entire hatch and be done with it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LilHot
Aug 19, 2015 10:02 AM
3rdgenparts
Aug 8, 2015 07:09 PM
