runs in clear coat
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
runs in clear coat
painted car came out fine except I two runs in one on each 1/4 panel in the same place. how do i fix these?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: runs in clear coat
If your clear coat ran a tad, you'll need to wetsand. Just make sure you use a very fine grit, as you don't want to break through the clear, trust me....
Transmission: A4
Did you not plan on wetsanding and buffing after you painted your car?
The paint must be wetsanded with at least a 1200 grit paper. I would go higher if you want a miror like finish without any orange peel. Then you have to buff it first with some type of rubbing compund. After that use a machine glaze from 3M. The machine glaze step will bring the shine back. I like to go back over the paint with a hand glaze from 3M. Stop by a local body shop and ask them for a some tips. They may be able to help you get the proper products needed to do the job.
As for the runs in the clear, You can wetsand them down if they are not big. If you have this massive drip then I would try to cut it off with a razor blade. This is one of those do at your own risk kinda things though. I have no problem doing it but I have also done it a few times.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
