My LED conversion has started.
Old May 17, 2008 | 10:59 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
So far I've got the following:
  • Dome
  • Rear turn indicators
  • Rear brake lights
  • Rear side lights (in the wraparound triangle portion of the tail light)
  • Automatic shifter console light
Taillights+turn indicators:
http://www.youtube.com/watch?v=f3Du59wwhyw
http://www.youtube.com/watch?v=pgCWacmyAQA
What's next on the agenda?
  • Front turn indicators
  • Backup lights
  • License plate lights
  • Rearview mirror map lights
  • Instrument cluster (white)
The sites where I got the bulbs are:
http://autolumination.com
http://superbrightleds.com
LEDs are defiantely the way to go.
Old May 17, 2008 | 11:13 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: My LED conversion has started.
did you have to replace the flasher to work with your new LED turn signal bulbs?
Old May 17, 2008 | 11:48 PM
VonKaiser's Avatar
Yes, I bought the EL12: http://autolumination.com/equalizers.htm
Old Jun 12, 2008 | 10:11 AM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
Okay, I have an 89 firebird and I have the gts blackouts on the rear. I am wanting some brighter bulbs to be seen through the blackouts since just regular bulbs are quite dim thought the blackouts. Do you think that the led's would be a good choice to go with to replace for a brighter bulb? Just kind of looking for ideas.
Old Jun 12, 2008 | 10:44 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Did you have to add any load resisters ? To me that just seems like a waste, since part of the reason to use LED's is their low energy usage, and the load resisters nullify that.
Would also be good to replace the under-hood light. Since the temp changes make that an incadescent killer.
Linson
Oct 24, 2025 02:00 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
