Door Locks
Old Jun 4, 2008 | 04:37 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Door Locks
My drivers side door lock isnt working when i use the key. Just wondering how hard it is to replace them?
Old Jun 4, 2008 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Door Locks
Remove the door panel, then the linkage. There's a "U" clip that holds the lock in place. SOB to remove--at least that's my experience. Set aside a morning or afternoon.
JamesC
Old Jun 4, 2008 | 08:48 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Door Locks
the "U" clip is usually rusted in place or held in place with years of dirt so don't just pull it straight out, try to wiggle it a little while pulling it, makes it a whole lot easier.
Old Jun 4, 2008 | 09:47 PM
tripingeorge3's Avatar
Re: Door Locks
take of inner panel. use long screw driver . pop off c clip. pick up out of door . pull out look. unclip from the rod. install new one. while you're at it wet/dry vac the inside of your door. after u pick up the c clip.
Old Jun 4, 2008 | 09:51 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Door Locks
If you can insert the key and turn it, the rod is already unhooked. May just have to reinstall it.
Old Jun 4, 2008 | 10:51 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: Door Locks
Thanks everyone for the info. The lock doesnt unlock or lock the door, so it might just need hooked up.
Old Jun 5, 2008 | 01:42 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: Door Locks
yea, my passenger side does the same thing. i just don't want to screw around with it right now. but i'll do it one of these days.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
