what sandpaper do u recommend to remove orange peel on single stage black?
Old Jun 22, 2008 | 11:10 AM
tripingeorge3's Avatar
i'm out of black single stage and can't buy more due to the fact this is my second gallon of black due to the instruction being wrong on the can. i have 2 coats of color on and basically need to sand smooth so i can apply xtreme clearcoat. i keep reading about which different sandpaper to use , but they don't seem to apply to my screw up. what sandpaper do ya'll recommend for my problem. i have orange peel all over, when i layed my stripes i sanded with 320 for them to stick and didn't go through the paint, but even with 320 it was a pita to get smooth. that was on the hood though. the rest of the body doesn't seem as bad. but here's the pics of my situation and it single stage that i will apply clear over: help please
mm
Old Jun 22, 2008 | 02:53 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: what sandpaper do u recommend to remove orange peel on single stage black?
around 600
Old Jun 22, 2008 | 03:11 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
not 600,that is for when you are repainting or reclearing that panel.go 1500. that paint looks like it was sprayed rather dry
Old Jun 22, 2008 | 03:18 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
1500?? I'd use that to wetsand and buff it but hes just applying clear so you need to have a surface for the clear to stick to which is why I said 600, but with 600 you will probably be able to see some scratches in the black.
Old Jun 22, 2008 | 03:28 PM
wouldn't i have to work my way up to like 1200 from the 600 or something before the clear?
Old Jun 22, 2008 | 03:33 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
personally I don't like to spray any material on a panel that has been sanded with anything over 600 grit because I fear the paint will have no where to stick.
Old Jun 22, 2008 | 06:40 PM
i'm scared of spray on surfaces above 600 too, but clearcoat applications seem to be different. but if my paint would have came out better i could of sprayed the clear right over it which would have been shining and smooth. i don't know
Old Jun 22, 2008 | 07:52 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
that single stage was sprayed on way to dry, you have issues on your hands now....start with 400 wet and work your way up...then clear it...i hope it works for you, and you dont have to strip that car and start again.
Old Jun 22, 2008 | 08:06 PM
i've wetsanded the hood. i started with 600, 1000 and ended with 1500. i have very little orange peel lleft but nothing that bothers me . you see it in a few places, but one thing i've learned in this process , is not to push it.looks alot better. the rest of the body isn't that bad. from my testing with the sand paper , i'll probably start off with 800 for the rest of the body. for some reason i had the spoiler hanging and it came out perfect and thats the same way i painted the rest of the body. oh well. anyway i have to make it look better than macco.i have alot of people at my job anticipating the results.
Old Jun 23, 2008 | 07:27 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
there is no other way to learn except letting you ***** hang and know you are going to $#&^ something up
Old Jun 23, 2008 | 09:49 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
dont go below 1200 or you will be repainting!!!
Old Jun 23, 2008 | 11:11 AM
jamon8's Avatar
Engine: 350 tpi
I have sanded w/400 and brought it back up w\800 then 1200
bling bling
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
3rdgenparts
Aug 8, 2015 07:09 PM
