ground effects?!??!?
Old Jul 4, 2008 | 02:17 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
how do you remove the ground efx off the side of a camaro(91) i took all the bolts out, but i didn't wanna break it tryin to get it off, we jus started body work so we need these off the car.
thanks for the help
Old Jul 4, 2008 | 04:27 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: ground effects?!??!?
under the badge on the front of the g.f.x. are two screws . remove badge to gain access . on the rear of the g.f.x. are two nuts . you need to remove rear seat plastic armrest panel to gain access . good luck .
Old Jul 4, 2008 | 08:03 PM
loud91rs's Avatar
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
Actually for a 91 camaro there are two studs that are behind the badge but you DO NOT have to take the badge off. Undo like 3 or 4 of the push pins for the wheel well plastic and reach your hand in there with a 10mm wrench and two speed nuts hold it on from the front. Then remove the screws along the rocker top with a phillips screwdriver. Then use a 10mm I believe socket and take out all the bolts that are attatching the tabs on the bottom. Then take out the sail panel on the interior in the back and poke through the hole that is covered with some kind of like tar paper or whatever and behind there should be two more nuts holding on the rear. Then it's out.
Old Jul 5, 2008 | 10:11 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
loud91rs is correct on everything.
But you don't really have to remove interior pieces and rear seats to get to those mounting tabs.I have removed several by just removing the plastic vent in the rear of the door jamb and reaching in with a small socket/wrench
whatever was easily available and unbolted them that way.
Just sounds easier to me to remove 1 screw to remove that vent piece than pull interior parts,fight with seatbelts getting in the way etc....etc...
Old Jul 5, 2008 | 11:45 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Gonna call you plastic man from now on.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
