Gas Tank question
Old Jul 26, 2008 | 07:45 AM
kevingrealish's Avatar
Car: 84 Z28
Engine: 350 V8
Transmission: 5 speed
Gas Tank question
I have to drop the gas tank in my 84 Z28 and replace the sending unit. Can anyone tell me the best way to drop the tank?
Old Jul 26, 2008 | 09:45 AM
cdoyle's Avatar
Re: Gas Tank question
Yep, lower the rear end as far as it can go.
I also removed the exhaust out of the way too.
Also, have someone help you do it, since it's awkward to move around.
Old Jul 26, 2008 | 02:57 PM
Car: 84 Z28
Engine: 350 V8
OK so how do I lower the rear end?
Old Jul 26, 2008 | 05:45 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
http://www.users.qwest.net/~nscamaro.../FuelPump1.pdf
http://www.users.qwest.net/~nscamaro.../FuelPump2.pdf
http://www.users.qwest.net/~nscamaro.../FuelPump3.pdf
http://www.users.qwest.net/~nscamaro.../FuelPump4.pdf
http://www.users.qwest.net/~nscamaro.../FuelPump5.pdf
Old Jul 26, 2008 | 07:01 PM
sgtmac's Avatar
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
Tank removal can be accomplished in a day if you have good luck with rusted bolts and nuts coming off without too much trouble. Getting the rear end down low enough(or removing it altogether) is the key to getting the tank neck down out of its hole. If you're dropping the tank, you'll want to replace it or have it professionally cleaned(mine had an inch of junk in the bottom of it even though it didn't leak)before putting it back in. Also, you probably have an in tank filter that needs to be replaced. And if you're dropping the tank anyway, you might consider urethane bushings, new shocks, cleaning up the bottom of the body, lots of image enhancing things can be done with the rear end out of the way. New tank at Autozone goes for about 160. I put a nine bolt with disc under mine when I pulled the tank.
Good luck, post some pics if you can.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
