Tips on changing a hatch
Old Jul 29, 2008 | 11:41 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone got any good tips to changing a hatch???
Gonna put my notchback on
Old Jul 29, 2008 | 11:50 AM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Re: Tips on changing a hatch
Get someone to help you - it's heavy. 13mm on top, 5/16 at struts.
Old Jul 29, 2008 | 12:02 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
No doubt, LOL. I had a friend help with mine and I only thought my shocks were completely shot. I held it up while he unhooked the shocks, and when he did it seemed like the weight doubled . Take the hatch off with the hinges attached, that's the easiest way. Before you put the new one on put a little silicon under the hinges to prevent leaks.
Old Jul 29, 2008 | 12:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
So remove the hinges from the car, leave attached to the hatch?
Old Jul 29, 2008 | 12:47 PM
87GTAj's Avatar
Engine: 5.7L TPI
I don't know about the notchback; does it have hinges attached to it? If so, you'll have to remove the ones from the car. I just left mine attached to the car because I was just removing the hatch for paint.
Old Jul 29, 2008 | 01:12 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
If you remove the hinges from the car you can unbolt them from inside with the hatch lowered. Then simply lift the hatch from both sides and the whole thing comes off, hinges and all. If you try to remove just the hatch and leave the hinges you will have to unbolt it with the hatch up, which is more difficult IMO. Removing the hinges also gives you a good opportunity to repaint them if needed.
Old Jul 30, 2008 | 12:48 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
So Ill remove the shocks first, both are blown, then re close and unbolt hinges from the car and remove hatch.
Only fun part will be drilling new holes for the stock wing, mahbe if I take that partoff the stock glass, whole metal piece it can be layed on top to help.
hydrolic144
Sep 8, 2015 06:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
