back hatch will not open
Old Aug 20, 2008 | 12:06 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have a little problem my back hatch will not open I put the key in the key hole but it will not turn left or right. the only thing i can do to open it is press the hatch button in the interior.
Old Aug 21, 2008 | 02:13 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Re: back hatch will not open
It's possible that either the hatch lock or the door locks got changed at some point and your key only works for the doors.
Old Aug 21, 2008 | 04:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well before your button stops working pull the lock outof the trunk and take it into a locksmith, he can make a key or just read numbers off lock and make one.
But you need to remove the lock first, they charge 3 times more if you don't.
Old Aug 23, 2008 | 12:24 PM
MetalGecko's Avatar
Did you check your key to see if the bumps on top are worn or rounded? If so you might need a locksmith, because the tumblers might not be moving to the right positions.
Old Aug 23, 2008 | 01:24 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I would try spraying some lube in the cylinder first. It may be frozen from not being used. If it doesn't work, I would pull the lock and have it re-keyed to match your existing door key. Call a local GM dealer or a locksmith and see if they do it there. For a reference, I charge $45 at work to re-key a cylinder.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
