Painting Engine Bay - Paint & Rust Fix, Need ADVISE
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I'm painting the engine bay black (to hide the colour change). I was going to sand down the light surface rust (with 240 grit) and then use black Tramclad to cover.
For the bottom of the rad support member, I was going to use POR 15.
Is this the way to go (I have never done this before
Can I just paint on the POR 15 or do I need to prep (with what)??
Need some overall advise......THANKS
This is what I am working with.
Bottom of rad support
Battery Tray
Pass Side of Engine Bay
)??Can I just paint on the POR 15 or do I need to prep (with what)??
Battery Tray
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Painting Engine Bay - Paint & Rust Fix, Need ADVISE
Good luck and have fun...
PS Wear Gloves
Car: 89 IROC
John (Okfoz)...thanks, great info.
It there any difference between Tremclad and Dupli-color? Is one better than the other as a spray on?
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
My battery tray is in almost the same condition. Looks worse from underneath.
AkDrifted
Aug 17, 2015 07:45 PM
