Converting to 4th gen seats?
Old Aug 28, 2008 | 12:12 PM
Nugget2109's Avatar
How hard is it to install 4th gen camaro seats into a 92 camaro?
do
Old Aug 28, 2008 | 02:46 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: Converting to 4th gen seats?
hey man i have a set in my 86 iroc-z. It is a direct bolt in. Just buy a set and bolt them in. Simple as that. -Matt
Old Aug 28, 2008 | 08:13 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
less than an hour. 30 min to take out old seats, 30 min to put in new seats.
Old Aug 28, 2008 | 08:52 PM
91CCFirebird's Avatar
Are the 4th gen seats any taller or do they sit any higher? I am 6'3" and have no headroom to spare.
Old Aug 28, 2008 | 09:27 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I swapped from gta power seats to manual 4'th gen seats because they are much lower, I am 6'5" and can sit comfortably now, I used to wack my head on the roof. You get bout 2 more inches with 4'th gen manual over 3'rd gen power seats.
Old Aug 28, 2008 | 10:03 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Heres a shot of mine.
http://i120.photobucket.com/albums/o...A/000_0009.jpg
Old Aug 29, 2008 | 03:49 PM
bigc4rmdacityla's Avatar
Car: 1988 camaro iroc -z
Engine: 5.7 350
Transmission: 700 r4
hey, will the seat track from a 4th gen fit, cuz the tracks on mine is broke
Old Aug 29, 2008 | 04:55 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
direct bolt in!
Old Aug 30, 2008 | 01:22 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
INSTRUCTIONS FOR 4TH GEN SEAT SWAP:
1 Remove plastic trim peces that cover bolts (If still present)
2. Remove 4 bolts and nuts (13 mm. 8 per car.)
3. remove seats (2 per car)
4. place new 4th gen seats in car, lining up bolt holes/studs as needed.
5. Re-use old bolts/nuts from 3rdgen seats, tighten as needed.
6. If new seats came with plastic trim for bolts, reinstall them
7. Sit on drivers seat and feel truly comfortable for once!!!!
LOL, this swap is the easiest of all swaps to do. As hard as it is to believe, there are many GM seats that are a direct bolt-in for third gen camaros. I have even heard that mustang seats will bolt right in, though, I've not seen it myself.
Hope this helps!!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
