Power Window Regulator Rivit Size?
Old Sep 7, 2008 | 07:09 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Anyone know the size rivets needed to replace the rivits for the window regulator?
Also what type of tool do I need to put them in?
I am tired of trying to get my fat hands in there to put bolts in.
Old Sep 7, 2008 | 09:11 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Re: Power Window Regulator Rivit Size?
1/4" peel rivets and use this:
http://www.harborfreight.com/cpi/cta...emnumber=41291
I am painting a door right now and I am thinking about tack welding small nuts on the regulator. That way I can just screw or bolt it in.
Old Sep 10, 2008 | 02:17 AM
Frank89IROC's Avatar
When I replaced my driver side PW motor, I used the little screw & nut that came with the new motor on 2 of the holes. On the third hole, where it seemed impossible to hold the nut in place, I used a sheet metal screw and it has held fine (over 2 years).
Old Sep 14, 2008 | 11:39 AM
69-er's Avatar
I didn't know there was a rivet that size available. I tack-welded the nuts too and it worked perfectly.
Larry
Old Sep 14, 2008 | 01:22 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
heres the rivets...
http://www.clipsandfasteners.com/1_4...pas4008-25.htm
Old Sep 14, 2008 | 01:32 PM
Joelfke's Avatar
Car: 1991 Camaro RS Conv
Engine: 305 V8
i did mine not 2 weeks ago....i just used a standard 3/16 rivet and i put a washer on both sides of the rivet (with the help of a friend) and they held up pretty good.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
