paint help
Old Sep 18, 2008 | 08:24 AM
camaro2172000's Avatar
paint help
Hello to all. I have a 1988 iroc. That has this big white spot on the roof of the car. Before i got the car it was parked in a garage for years and when it would rain the roof would leak and was told that is how the spot got there. any one know if and how i would go about getting it out of the paint? t/y
Old Sep 18, 2008 | 08:35 AM
sxciiZ's Avatar
Car: 1984 camaro Z28
Engine: 305, 5.0 L
Transmission: 5 spd
Axle/Gears: 3.55 i think
Re: paint help
Try a clay bar, maybe that would help!
Old Sep 18, 2008 | 02:26 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: paint help
thats clear coat oxidation, only successful way I know of getting rid of that is sanding it away and re-clearing. however at that point you miswell repaint the whole car so it'll match.
Old Sep 18, 2008 | 06:54 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Re: paint help
Id say try to buff it first but it looks to far gone. You can make it look good without having to paint the whole car if the paint on your sail panels is good, not oxidised. Sand and prime the roof, 220 grit and use a good high build primer. Paint the roof blending out the color to the A pillars and the sail panels. Clear the roof, clear the A pillars down to where they meet the fenders and clear the sail panels about half to 3/4 down. Once the clear has hardened buff off the sail panel area. Blending like this will leave no hard line, just a dull area where the clear gets real thin. Its tough to discribe but I hop that helps.
Old Sep 19, 2008 | 05:39 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: paint help
is this a common problem? it just seems odd that rian water would do this. especially out of the sun in a garage. anyways good luck with whatever you decide to do.
Old Sep 21, 2008 | 10:42 AM
Re: paint help
Hey thanks for the help guys. Maybe i will try the clay bar and if that don't work. Guess i'll have to redo the whole roof. irockid That is what i was told by the person i got it from. Was his dads car and he passed away. So he wanted to sell it and that is how i got it. Sounds kind of funny to me also that rain would do that. You can rub your hand across the paint and when you get to the white in the paint it is real coarse. The car only had 5000 miles on it when i got it.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
