Small Hole in floor
Old Oct 23, 2008 | 04:56 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Small Hole in floor
I pulled my carpet up in my 83 TA found a few small holes in the floor,
what should I use to plug them? Bondo, Also what can I use for rust before I
install the new carpet.
Thanks for all your help.
Old Oct 23, 2008 | 09:12 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: Small Hole in floor
Cut out as much the rust as you can so it doesn't spread
Get some sheet metal and weld it in (Some people rivet it in, but some swear that it wont hold up, i don't really know, if you rivet it in make sure to use seam sealer)
Some people may say buy new floor pans, but that's alot of bank for a few small holes.
You might wanna spray whatever u put in to repair it, with some rust product, maybe por15 or something. (Could go head and spray the whole floor with it)
Old Oct 24, 2008 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check out POR-15 products. I used it to repair a 2 x 6 hole several years ago, and all's well today. Highly recommended.
JamesC
Old Oct 24, 2008 | 02:09 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
cut out the rot, get sheetmetal and weld it in. if you can't weld then use JB weld, thats what I used and it worked good. I'd rather have welded it but my welder was down.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
