Bumper Question
Old Nov 25, 2008 | 07:33 AM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Bumper Question
I just ordered a 1985-up bumper cover for my 1984 car. I personally like the cleaner lines of the later models and the 'air dam' will blend nicely into the IMSA front fenders.
Can I reuse my '84 bumper reinforcement with my new cover?
Also, is it possible/advisable to stabilize the back of the bumper cover with some polyurethane insulating foam? The top of the cover between the parking/signal lights and the centerline has a tendency to go concave with age. This has happened with this car and it was starting to happen with my ex-86.
Old Nov 25, 2008 | 08:32 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Bumper Question
I'm pretty sure the bumper impact bar is the same but I'm not sure about the impact absorber.
Not sure what the insulating foam would get you. You may need to back it up with something.
Old Nov 26, 2008 | 02:07 AM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Re: Bumper Question
Thanks for your answer. I've been advised to use chicken wire or expanded aluminum mesh as a matrix for the polyurethane foam. I will do some research in the aviation sector. They use a lot of 2-part polyurethane foam in homebuilt aircraft construction.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
mikey8494
Aug 22, 2015 07:57 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
