My ground up (Start to finish) thread
Old Aug 2, 2009 | 11:34 PM
  #101
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: My ground up (Start to finish) thread
Originally Posted by Ca[maro]88
you going with adjustable lca's or just runnin with the stock ones?
i will be making my own LCA's once i wrap up some goals i set on the car one of them being to cap the subframes and get them done and find out what i want to do for a coating, bolted in and run a few tacks. still need to wire up the car the list goes on but i try to take it one day at a time
Old Aug 3, 2009 | 12:31 PM
  #102
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
cool sounds pretty sweet. what color blue is that? just a rattle can i assume?
Old Aug 26, 2009 | 01:00 AM
  #103
87camarov6's Avatar
Dang thats what all camaros deserve. nice work man. How much did that all cost?
Old Aug 26, 2009 | 05:13 PM
  #104
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Wow! It's been a little bit since I last checked on your project, and it looks like you've come a lot way. Very nice work bro. Makes me feel bad about my slow progress on my own project, almost a year now and I'm still working on the teardown. Oh well, that's life though. Glad to see you're getting there, way to go!
Old Aug 28, 2009 | 11:46 AM
  #105
crazy_hotrodder's Avatar
Car: 92rs
Engine: 355
Axle/Gears: 4.10 7.5 with auburn posi
oh my god, nice build, impressive work, keep it up, I love the way it's coming along.
Old Sep 11, 2009 | 10:33 PM
  #106
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
you get those nise homeade SFC's in yet? i gotta see those beauts installed!!
Old Sep 22, 2009 | 11:48 PM
  #107
FueledSoul's Avatar
yea just primmer/paint, i forgot the name of the color all have to look at one of the cans
Old Sep 22, 2009 | 11:49 PM
  #108
FueledSoul's Avatar
Thanks! i dont know yet im not done ?
Old Sep 22, 2009 | 11:52 PM
  #109
FueledSoul's Avatar
Thanks, yea i hear you there. good luck on yours got any links to how yours is going?
Old Sep 22, 2009 | 11:53 PM
  #110
FueledSoul's Avatar
Thanks!
Old Sep 22, 2009 | 11:55 PM
  #111
FueledSoul's Avatar
not yet all be getting around to it maybe in the next couple of weeks
Old Sep 22, 2009 | 11:58 PM
  #112
FueledSoul's Avatar
Heres the upper panhard bar i made
Old Sep 23, 2009 | 08:51 AM
  #113
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
gorgeous! i hope you plan to weld those LCA RB's to the rear housing...
Old Sep 23, 2009 | 09:39 AM
  #114
FueledSoul's Avatar
Thanks. nice A.T.D yea i plan too just havent got around to it yet im also trying to see how i can keep the LCA arms at the same angle its hard i keep getting each one off 2 to 3 degrees from the other side all have to think about how to go about getting both LCA angles perfactly even if thats at all possabile.
Old Sep 23, 2009 | 06:58 PM
  #115
Bear8976's Avatar
This is looking Amazing!! Great Job!! Is that the Stock Rear End for the Camaro?
Old Sep 23, 2009 | 08:07 PM
  #116
FueledSoul's Avatar
Thanks, not stock for my car. i took it off another camaro i had at one time. A few pages back i think i posted pics of it before it was installed
Old Sep 23, 2009 | 09:40 PM
  #117
mw66nova's Avatar
Engine: 7.0L
so, i know that you put girdles on the cover to help out with some extra strength back there, but did you also put pre-load bolts in to preload the bearing caps? the big aluminum girdle covers are only good because of these preload bolts....otherwise you just kinda wasted your time on that one.
sure looks neat though...this is coming from a guy that has extra tubes welded into the rollbar, just cause it's cool looking
Old Sep 23, 2009 | 10:03 PM
  #118
FueledSoul's Avatar
yea i figered it would at least add some rigidity def not like the ones that incorporate the mains but it works
Old Sep 28, 2009 | 06:36 AM
  #119
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Is it necessary for the lowered control arms even if you have the new tubular torque arm? Is the traction increase noticeable?
Old Sep 28, 2009 | 08:37 AM
  #120
the lowered control arm brackets keep the axle centered in the wheel wells after lowering. without them the wheels will be closer to the rears of the quarters.
Old Sep 28, 2009 | 04:31 PM
  #121
mw66nova's Avatar
Engine: 7.0L
best real world explanation i can come up with:
https://www.thirdgen.org/forums/susp...arm-angle.html
Old Sep 29, 2009 | 10:12 AM
  #122
BMR Sales's Avatar
Former Sponsor
Everything looks good so far!
Old Sep 29, 2009 | 04:36 PM
  #123
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Amazing build. Nice to see our cars being beefed up.
Old Oct 19, 2009 | 09:23 AM
  #124
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Originally Posted by FueledSoul
Nice to your 20 year old craftsman jack works perfectly still too....lol I couldn't resist
Old Nov 2, 2009 | 05:22 PM
  #125
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
looks good. it's given me a few more ideas to add to my car. good work, im going to watch this
Old Dec 23, 2009 | 04:35 AM
  #126
Engine: 350/350/LS1
wats going on with the car, ive been following all the other threads and can't wait to see all of this done
Old Dec 23, 2009 | 07:54 PM
  #127
tim84berlinetta's Avatar
Car: 1984 camaro berlinetta,86 300zx
Engine: crappy 305
Axle/Gears: stock
Wow your car looks nice.Great job
Old Apr 1, 2010 | 03:01 PM
  #128
FueledSoul's Avatar
Thanks for the complements.
kinda old news but i had to make some plates to raise the transmission up with the new cross member. i ended up using two 1/4" plates. if i didn't my headers would hit the already notched out a-arm ears.
I order some UMI lower control arms from summit on when UMI had there 20% discount and i had a coupon from summit for $20 off orders over $100 so i got them cheaper then i could have made them for. i painted them to match the rest of the parts under the car.
The undersides and suspensions almost done. i have to get an alignment,
i want to have the car on a frame rack to make sure the chassis is 100% i got sub frames to wrap up and powder coat and weld on the car along with lower control arm relocation brackets to weld on and lower control arms to bolt on. exhaust kit to assemble and a y-pipe to fabricate. i might have to pull the front drivers side coil and re-weld a area i notched/patched it seems i didn't get enough penetration from the back side. after all that i plan on getting weight jacks probably after the cars done.
Old Apr 1, 2010 | 03:11 PM
  #129
FueledSoul's Avatar
oh and all probably get some misalignment collars and a rod end for the pan hard bar i have now and then reinforce the panhard bracket. its on my list of things to do but its not that important right now
Old Apr 16, 2011 | 12:31 AM
  #130
FueledSoul's Avatar
I ended up buying bolt on LCA Relocation brackets, the ones with out the shock tabs are harder to get match up relatively to each other.
I got my sub-frames fully welded, i will probably clean them up media blast and powder coat them but not till after im done mocking up and install my exhaust.
Pulled everything but the K-member got it ready to permanently weld in the nuts on the bottom and install poly motor mounts. And i can get to painting the front of the underside now.
After the poly mounts are in then i have to fix one issue that's been bugging me, someone had striped some of the transmission cross member threads and used mismatched bolts. My plan is to take out the bolts and drill pilot holes from under the car though the organelle holes and then hole saw from the top drop in M10 bolts and weld them in and use a washer and locking nuts at the bottom. After that's done its on to the exhaust...
I had bought a magnaflow cat-back several years back before they become popular on tgo, I have had magnflow on my 4thgens and liked the sound and the fact every things stainless i might looking into something different like borla or corsa or i may keep it will see.
I have came up with my own stainless mandrel bent y-pipe kit iv tried to sell in the tgo classifieds if i can get some sold i will produce more.
Old Apr 16, 2011 | 12:59 AM
  #131
FueledSoul's Avatar
Old Apr 16, 2011 | 05:45 AM
  #132
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
If you're goung to change from the Magnaflow kit, go with Corsa.
Old Apr 16, 2011 | 08:32 AM
  #133
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
make sure you have plenty of room between the exhaust and the subframe connector....mine vibrates against it.....now i gotta remove the exhaust a grind some of the subframe away to make room.....it's tight under there! your picts look great!
Old Apr 17, 2011 | 11:04 PM
  #134
FueledSoul's Avatar
hopefully i wont have that problem if i do run into clearance issues i will make some oval tubing.
Old Apr 17, 2011 | 11:11 PM
  #135
FueledSoul's Avatar
I got the 6 nuts welded to the k-member so much easier to do mounts wish i did this when i had it all apart before. I got the poly mounts installed, Im glade i did seems it corrected some issues, The headers have more clearance on each side since the engine sits 1/8 to 1/4 higher. Even with these mounts one would still have to modify the k-member and a-arm pockets for the headman long tubes.
Old Apr 17, 2011 | 11:15 PM
  #136
FueledSoul's Avatar
Unloaded height differences. Possibly because the rubber ones are wore out
Old Apr 17, 2011 | 11:17 PM
  #137
FueledSoul's Avatar
Here is how shitty the rubber mounts were.
passenger side.
driver side.
Old Apr 17, 2011 | 11:20 PM
  #138
FueledSoul's Avatar
Old Apr 18, 2011 | 04:41 AM
  #139
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Old Apr 18, 2011 | 05:44 PM
  #140
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
New Linkage Vs OEM stock
where you pick that up at?
Old Apr 18, 2011 | 10:12 PM
  #141
FueledSoul's Avatar
If you looked on page 2 i had posted about it.... but here,
Been asked several times what im running so im posting a list of parts
Moog AMGK6145T $29.39
Summit SUM-TR-2227L $26.95
Summit SUM-TR-2226R $26.95
Energy Suspension 9-13101G $3.95
Edelbrock 5250 $37.95
PST GNSP00246 $47.00
PST GNSP00147D $47.00
http://store.summitracing.com/partde...5&autoview=sku
http://www.p-s-t.com/pc-521-21-chevr...o-1982-92.aspx
http://www.p-s-t.com/pc-4174-33-chev...o-1967-92.aspx
Old Apr 21, 2011 | 10:07 PM
  #142
d2harris's Avatar
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
Great thread, I just found rust in my floor pans and discovered my sway bar isn't even connected. Will probably have to do the same to my car in the future, keep up the good work!
Old Apr 22, 2011 | 01:56 PM
  #143
FueledSoul's Avatar
Thanks, and good luck with your future project .
So i got the entire front underside painted.
I spent about 7 hours prepping and painting.
I have a few spots where trans frame rails are that i couldn't get to due to how the cars sitting. This is all i got for pics for the moment.
Old Apr 22, 2011 | 09:56 PM
  #144
crzytuner2's Avatar
Project looks awesome. Can't wait to see more pictures of the progress. I know there's gonna be a ton of pride in completing that job.
Old Apr 23, 2011 | 02:44 PM
  #145
dmosley73's Avatar
how much did your car sell for once you were done with all that work? i am doing the same thing to an 83 z28 so i am curious as to what i am going to get for it
Old Apr 23, 2011 | 11:33 PM
  #146
FueledSoul's Avatar
Thanks, should get some more by next week
Have no idea what your talking about, Cars not for sale.
Old Apr 24, 2011 | 10:31 AM
  #147
dmosley73's Avatar
my bad, i must have got the post mixed up.
Old May 3, 2011 | 08:16 PM
  #148
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
subscribing
Old May 25, 2011 | 06:06 PM
  #149
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Subscribing, awesome work. I want to do the exact same to my car, just need to sell another one of my camaros first
Old May 25, 2011 | 08:09 PM
  #150
DanTheAngry's Avatar
Car: 87 Trans Am
I have to do something similar to the bolts on my transmission cross member. I had planned on a similar fix.
Please take some detailed pics of your fix it would really help me out.
