Can Hoods with loavers and blisters be made functional?
Old Dec 2, 2008 | 01:11 AM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
If so could someone tell me how this can be done? I like these types better than cowl hoods and i think with an open element filter this could greatly improve breathablitliy. Thanks.
Old Dec 2, 2008 | 10:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Can Hoods with loavers and blisters be made functional?
cut the metal under the vents and brace around the cuts if you want your hood to be nice and solid.
a plasma cutter would be nice, I know I want one
Old Dec 2, 2008 | 11:00 AM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Do a search, there's a thread devoted to making those things functional. One person ended up having the engine heat melt their louvers but another person seems to have had good success.
Old Dec 5, 2008 | 03:47 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I've cut mine to make them functional. I made sure to leave some horizontal bracing on the hood and leave the braces on the louvers intact and so far I haven't had a problem with any kind of warping.
Attached Thumbnails Can Hoods with loavers and blisters be made functional?-0805072019-00.jpg   Can Hoods with loavers and blisters be made functional?-picture-031.jpg
Old Dec 18, 2008 | 09:52 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what kind of louvers did you use? are they metal, or plastic, stock or after market? they look great.
Old Dec 18, 2008 | 10:50 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
He used stock louvers and cut pieces out of them. Ill let him explain that more. Also about hood blisters. I seen a guy cut a whole in the hood under the front of the blister so that you couldn't tell that it was there. Then he cut out the insert and put in a mesh grille so that heat could escape out of the blister.
Attached Thumbnails Can Hoods with loavers and blisters be made functional?-dscn0004-1-.jpg   Can Hoods with loavers and blisters be made functional?-mvc-b1f.jpg   Can Hoods with loavers and blisters be made functional?-mvc-b6f.jpg
jaridjohn
Jul 8, 2024 03:49 PM
colton_carlson
Mar 8, 2019 12:21 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Anomaly
Canadian Region
Aug 31, 2015 12:44 AM
Wife'sCar
Aug 22, 2015 01:46 PM
