Painting Headlight Pockets.....
Old Dec 6, 2008 | 11:57 PM
xNJ92RSx's Avatar
Car: 1992 rs
OK, so I really want to paint my headlight pockests satin black ( thats what color I was told that they really are) I havent really done any serious auto painting before. But Id really like to do it myself. could any of you, give me some tips as far as the process goes? like do i have to wet sand or just sand the old whit paint thats on their now, then prime it then lay down the black, and then the clear coat? As well as the right paint and clear.
-Pete
Old Dec 7, 2008 | 05:16 AM
kcb37's Avatar
Re: Painting Headlight Pockets.....
Clean it off, sand it with some finer grit, I would say something like 400 grit.
You shouldn't have to prime it unless you take off all the paint.
Clean it off again, tape it off, and spray it.
For little things like that most people just use a good aresol can.
You can wet sand it if you really want to.
Then clean and spary with a clear.
Wouldn't hurt to do several coats.
Old Dec 7, 2008 | 07:32 AM
skinny z's Avatar
There's a spray bomb available called bumper paint. I used a can of it to black out my headlight pockets. I use silicone/grease/wax remover as a cleaner after it's been sanded and taped. ( Not as aggresive as laquer thinner and dosen't leave a film behind likem paint thinner )
Old Dec 7, 2008 | 10:02 AM
xNJ92RSx's Avatar
Car: 1992 rs
Thanks, This may sound stupid but how should I clean it?
Old Dec 7, 2008 | 11:15 AM
skinny z's Avatar
Old Dec 7, 2008 | 04:49 PM
Phishman92's Avatar
Car: 92 25th Anniversary Z28/RS
Engine: 305 TBI.... (for now)
just to point out the obvious, if you want the satin aka "flat-ish" look, think twice about a clear coat. I had my whole car painted and specifically asked for flat/satin black on the pockets and hood blisters and the painters did just that. Then cleared the WHOLE CAR and turned the satin into a high gloss luckily the guy remembered me asking about that, and resprayed them for free...with a rattle can! and they came out perfect. I just had to respray them this past summer and the paint's been there for 5 years. Mostly resprayed because of sap damage.
anyways not sure if they make a satin clear coat but i just thought i'd add that little story before you made the same mistake they did.
Old Dec 7, 2008 | 07:20 PM
Diengrey13's Avatar
Car: 1988 camaro iroc-z
Engine: 350 t.p.i
Axle/Gears: 12bolt/posi
I would just use a semi-gloss black rattle can. Just wet sand with some 400 grit, primer it then sand it again and spray. I would recomend rustolem spray or krylon. The
Also "flat" black seems to trap more dust. I used smi-gloss plenty of times and still has the flat look. If you wanted to go with professional paint the painters often use flattend clear over the paint.
Old Dec 8, 2008 | 02:03 PM
sufferingant's Avatar
However you do it, make sure you take your time and be patient. Multiple coats help too!
Old Dec 8, 2008 | 04:09 PM
skinny z's Avatar
I've used this stuff with excellent results.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
