Just super! :) Hood latch cable broke or came undone after shutting hood.
Old Dec 20, 2008 | 11:38 AM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
the cabe is still intact from the puller to the underhood area i can hear it moving when i mess with the puller inside. but their is no tension at all when i pull it and the hood wont open.
yes yes its great.
any ideas. it is tpi with the factory ram air setup so it pretty much surrounds the latch.
sometimes you cant win....
any help would be greatly apreciated.
Old Dec 20, 2008 | 11:54 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Just super! :) Hood latch cable broke or came undone after shutting hood.
i dont know if it helps but here is a diagram of what you are facing. its in 2 pages.
at least you will know what you are touching when you reach under the hood.
good luck.
Old Dec 20, 2008 | 12:11 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks!
yes i cant rember does this hood utilize a pin style latch where the pin locks or does it use a bar syle where it latches onto a bar like a door latch is?
Old Dec 20, 2008 | 12:17 PM
recarosp's Avatar
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
if u get under the front u should be able to look up and see its a latch if u slid it to the left it should open
Old Dec 20, 2008 | 12:52 PM
Car: 89 Iroc
Engine: 5.7 TPI
yes thats kinda what i am thinking because its the pin style latch right?
so i should just have to remove the bumpers splash sheild and then the latched pin should be right their and i just slide the lock out?
Old Dec 20, 2008 | 05:01 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If the outer part of the cable has come out of the groove that holds it you can just pull on it to open the hood, if the actual inner cable part is still connected to the latch. Another common problem is that the hood sticks. If someone pulls on the hood release and you press down on the front of the hood and work it a little it may release. Remember also, the hood release handle has to go all the way back in before the hood will open.
Old Dec 20, 2008 | 07:07 PM
Car: 89 Iroc
Engine: 5.7 TPI
lol yea no i use to be able to just pull up or pop the hood literly i know the cable came off or broke right at the under hood latch 150% positive.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
cougar20th
Aug 27, 2015 08:04 AM
Randomtask2
Aug 13, 2015 01:57 AM
